Odd/Even throw-in betting is considered one of the many types of football side bets. Although it is not as widely played at the moment, this market is actually very interesting. Because not many people know about it, Odd/Even throw-in betting has not gained much popularity yet. That’s why in this article, bet win tips will share with you how this market works and why it can be surprisingly easy to win.
Details about Odd/Even Throw-in Betting
Odd/Even throw-in betting is a wager based on the total number of throw-ins in a match. Your task is simple: predict whether the total number of throw-ins from both teams will be an odd number or an even number.
If you bet Even, you only win if the total throw-ins end up as even numbers like 4, 6, 8, 10, 12, etc.
If you bet Odd, you only win if the total throw-ins are odd numbers like 5, 7, 9, 11, 13, etc.
Many betting experts rate this market as a 50/50 chance — meaning the odds of winning are relatively high. That’s why Odd/Even throw-in betting can be a smart option to try, especially at trusted good betting site like M88.
How to Calculate Winnings in Odd/Even Throw-in Bets
The rules for settling Odd/Even throw-in bets are very straightforward. For example, if Chelsea play Real Madrid and the bookmaker sets the odds:
Even=0.80
Odd=0.95
Then the payout will work as follows:
If you bet $100 on Even, and the total throw-ins are 4, 6, 8, 10, etc., you win $100 x 0.80=$80 profit.
If you bet $100 on Odd, and the total throw-ins are 5, 7, 9, 11, etc., you win $100 x 0.95=$95 profit.
You can also choose to bet Odd/Even throw-ins for the first half, second half, or the entire match. For example, if you lose in the first half, you can still place a new wager on the second half. This flexibility makes it easy to recover losses and continue betting.
How to Play Odd/Even Throw-in Betting at M88
If you want to enjoy this market safely, the best option is to place your bets at a reputable bookmaker like M88. The process is simple:
Create an account and deposit funds – Register at M88, then deposit any amount you wish before starting to bet.
Check the odds – Don’t place a bet immediately. Review the Odd/Even throw-in odds carefully to see which side offers better value.
Place your bet – Select either Odd or Even, enter the stake amount, and confirm your wager.
Confirm and wait for results – Once you’ve confirmed, all you need to do is follow the match and wait for the outcome.
Tips for Winning More with Odd/Even Throw-in Bets
From my experience betting at M88, I’ve developed a few personal tips that can help you improve your chances:
Watch the match live – Count each valid throw-in yourself to double-check the vip betting tips telegram channel settlement and avoid mistakes.
Understand team playing styles – Teams with more aggressive or wing-focused play usually create more throw-ins, which can influence whether the total ends up odd or even.
Check throw-in history – Review past matches to see whether a team’s games tend to end with odd or even totals. If two teams often produce even totals, you should lean towards betting Even, and vice versa.
Final Thoughts
Odd/Even throw-in betting is a lesser-known but highly attractive market in football betting. With a 50% winning probability and simple rules, it’s a great option for both new and experienced bettors. By following the strategies above, you can maximize your winning potential and enjoy betting at M88 with confidence.
